I like the idea of the Toggle command except that it becomes confusing to
have so many functions on a single icon... I find it hard to remember that
it does that, especially when not often used.
How about a swap button on the edit dialog also?
(I had a user request for this just this week too.)
John Pullen
"Nate Holt (Autodesk)" wrote in message
news:40814771$1_1@newsprd01...
> Michel,
> You can swap them but it's not easy. Here's how:
> 1. Get the block name of the symbol (use DDATTE or LIST). Block name for
> source arrows will be something like "HAxSy" where "x" = "style" number
and
> "y" = 1 for wire from right, 2 above, 3 from left, 4 from below. For a
> destination arrow symbol, it will be "HAxDy".
> 2. Use the AcadE SWAP BLOCK command and select "Swap a Block - one at a
> time" and "Pick new block from icon menu". Hit OK.
> 3. The icon menu dialog should display. In lower left-hand corner type in
> the new arrow block name, flipping the state of the 4th char of the block
> name from "S" to "D" or "D" to S" (example: if existing signal block is
> "HA1S2" then type in "HA1D2" to flip to a destination arrow). Hit OK.
> Maybe we should think about making the "Toggle NO/NC" command usable on
> these signal arrow symbols?
> Nate.
> "MICHEL" wrote in message
> news:24314679.1081944074526.JavaMail.jive@jiveforum2.autodesk.com...
> > Is there an easy way, after having created a source and destination
> signal, to switch them?..ie source becomes destination and vice a versa.
