AutoCAD Electrical General
Active Member
Message 1 of 4 (75 Views)
Right-click menu
75 Views, 3 Replies
12-09-2003 11:21 PM
I'm trying to add the wire angles 22.5 and 67.5 to the right-click menu. I'm copying the existing wires under the **Click... section(wire and wire45) and adding 22.5 and 67.5 verbatim to the menu, deleted files .mns, .mnc, and .mnr, recompiled the menu files, and its still not working. Getting Error message (Unknown command "WD_REACT_DO_INWIRE22".) Has anyone had any success trying to add items to the right-click menu?
*Autodesk, Inc\
Message 2 of 4 (75 Views)
Re: Right-click menu
12-10-2003 12:43 AM in reply to: cldubu2009
    You can add your custom routines
or existing Electrical routines to the right-click menu, but you cannot modify
calls "WD_REACT_DO_INWIRE45" and have it work.  That is a
specific routine being called and when you modify it, you new call can
no longer find a matching function to run.  You can, however, set it
up to call the general insert 22 wire command.  It just will not have the
same functionality where it selects the location you right-click as the start
point for the wire, you will have to make that selection.  For the specific
command calls, you can check out the specific toolbar buttons.  Here is the
entry I made to insert the angled wire from the right-click menu:
size=2>
[Insert Wire&22]^C^C^Pwd_in22wire
    This worked fine for me.  I
hope this helps!
Sincerely,
Jared Bunch
Technical Support Specialist
Autodesk, Inc
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
I'm
Active Member
Message 3 of 4 (75 Views)
Re:
12-10-2003 04:29 AM in reply to: cldubu2009
Thanks Jared for your quick response!!! I tried that right after I send this posting. Works just like you said. Any plans in the future to make this work like its suppose too? If not lets add this to the Wishlist.
Thanks again!!
*Autodesk, Inc\
Message 4 of 4 (75 Views)
Re:
12-10-2003 05:45 AM in reply to: cldubu2009
I will be more than happy to add this to the
wishlist.  Please keep in mind though that it is working properly.
The call you were making did not exist and that is why it would not
work.
Thanks, and have a good day.
size=2>
Jared Bunch
Autodesk, Inc
Thanks again!!
You are not logged in.
Manufacturing Community
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
