AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
STEVENAR
148 Views, 1 Reply
Reporting
Can someome please advise if it is possible to have more than 13 user attributes for reporting. There only seems to be 13 rows in the user attribute table.
Thanks & regards
1 REPLY 1
algerj
in reply to: STEVENAR
Hi Steve,
Through the Graphics Display I believe it adds additional ones as required (but only one at a time). it starts with 12 and when you use up to 12 a 13th appears, if you fill in 13 then the 14th appears (only after reopening the user attribute file [wda]).
I would suggest opening up the wda file in notepad and modifying it directly then you can have as many as you want.
My only question would be why do you need more than 12?
James Alger
”Boost
