AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Referencing
11 REPLIES 11
Message 1 of 12
Arati Tillu
180 Views, 11 Replies
Referencing
For Grid Referencing (horizontal & vertical ) I want to reduce the size of nos..(1,2,3..) & alphabets (A,B,C...).Also the size of lines separating them.
What is the significance of separator mentioned in referencing.
I have to do the referencing procedure twice to get grid reference.
11 REPLIES 11
Message 2 of 12
Arati Tillu
in reply to: Arati Tillu
please see the attached file for reference
Message 3 of 12
Vahees
If I am right about the problem, This is what you do:
Go to 'Config Drawing' and then select the 'Setup' Option under 'Reference'. Change Horiz & Vert spacing.
Message 4 of 12
Arati Tillu
I dont want to reduce the space between the nos , I want to reduce their scale.
Message 5 of 12
Arati Tillu
I think what you are looking for is the variable TEXTSIZE. Type
TEXTSIZE at the command line and set the value you would like (the text
height). Note that this needs to be done before the references are placed.
I hope this helps!!
Jared (Autodesk, Inc)
wrote in message news:4897443@discussion.autodesk.com...
scale.
Message 6 of 12
Arati Tillu
Your solution has perfectly worked.Thanks.
Message 7 of 12
Arati Tillu
Please also let me know whether textsize works to reduce the scale of the wire nos.
Message 8 of 12
Q6.1.1) How can I permanently change the text height of wire numbers?
A) To do this:
1. Determine the schematic symbol library in use and open drawing
"wd_wnh.dwg" in AutoCAD.
2. Adjust the WIRENO attribute's text height to your liking.
3. Save
4. Open drawing "wd_wnv.dwg", "wd_wch.dwg" and "wd_wcv.dwg". Repeat steps
2 and 3 for each.
That's it. Wire numbers for new drawings will come in with the new text
height. (old dwgs require ERASE WNUM and PURGE).
(from the "***FAQ*** posting)
wrote in message news:4901000@discussion.autodesk.com...
wire nos.
Message 9 of 12
jmburge
Does anyone know how to change the default color of a fixed wire number so it can be a different color than an unfixed wire number? When you set a wire number to fixed, the program maintains the same color. The only way I know is to double-click on the fixed wire number and change the properties.
Message 10 of 12
MartinLee
You can change the color of the layer. The fixed wire number should be on layer WIREFIXED. Mine is Color 130. If you have several drawings to change, you can write a script file with the name WIREFIXED.SCR
-layer ;Layer command w/o dialog box
c ;Selects color option
6 ;Desired Color (yours may be different)
WIREFIXED ;Layer to change
;Enter
;Enter
You can run the script porject wide.
Message 11 of 12
jlshapiro
Question is there a way to bring in the new wire text height w/out erasing the old text in the old drawings?
Message 12 of 12
Use the project-wide utilities to change font styles and size for all
symbols. Use Update Block to update just one symbol to the latest version
from the symbol library.
wrote in message news:5970656@discussion.autodesk.com...
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
”Boost
