AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
REPLACE OR UPDATE A TITLE BLOCK OR TEMPLATE IN A WHOLE PROJECT
9 REPLIES 9
Message 1 of 10
JEANNENEZ
15676 Views, 9 Replies
I had to modify my title block (Because the firma of my customer had changed their logo)...I have several projects of about 50 sheets where i have to update or replace the title block by the new.
Which is the solution for make this?
can you help me?
Best regards.
Jean-Marie
9 REPLIES 9
Message 2 of 10
in reply to: JEANNENEZ
This could work.
Open the first dwg of the project you want to update.
Use the "swap/update block" option. This is the last icon in the "insert component" fly out.
There you choose the 3th option "Swap a block project wide" and you thick also the 3th option on the left if needed "Browse to..........+". Better to unthick the option "Auto retag ........." also.
Click ok and browse to your new title block. Select it and select the block you would like to swap. Then you need to select the dwg's you would like to see updated.
Message 3 of 10
jmburge
Remember..."Swap" a block means that you want to replace the block you have with one of a different name.
"Update" block means just that...you want to update the symbol with a newer version of the same name.
I hope this helps,
John Burgess
Message 4 of 10
JEANNENEZ
Thank you for your help,
But this option "swap/update block" is ok for block components of librairy, but it doesn't ok for title block.
My titles block disappeareat..i don't know why!!!!
.to follow!!
Message 5 of 10
Here it works fine.
But i have tried it with a different name.
Now i have done it with the option "B" "Update a block" It works similar to the other one. This works fine for me. You can try it first on one drawing instead of directly on the whole project. also take the comments of John in consideration.
Message 6 of 10
JEANNENEZ
It doesn't work here, "swap" or "update" .i have ACE2007, and you?
Perhaps .it works with ACE2008
thank you for your help, i will try with ACE 2008.
Jean-marie
Message 7 of 10
Many thanks for the subject. I had the same problem and I found this discussion by searching. It works and my problem was removed.
Masoome
Message 8 of 10
me too get use of this discussion
thank you all
Message 9 of 10
shadow931
I can't find this option "swap/update block". Using Autocad Plant 3D can you tell me where it is located?
Message 10 of 10
jseefdrumr
in reply to: shadow931
That command is unique to ACAD Electrical
Jim Seefeldt
Electrical Engineering Technician
”Boost
