AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
RELAY & CONTACTOR COILS
1 REPLY 1
355 Views, 1 Reply
I was asked why when inserting a coil block at an intersection on a ladder, does i revert to vertical insert.
It should default always to horizontal unless the vertical check box is checked. or you are only on a vertical wire.
Any ideas?
Doug B
1 REPLY 1
testsubject
My guess would be because you are trying to insert the coil on an intersection. I would think that the coil would always be inserted on a wire by itself. Since the only continuous wire available at the intersection is the vertical ladder, I guess it is trying to insert it there.
Bob Hanrahan
Ace User since 1998
If this answered your question, please click on "Accept Solution"
”Boost
