AutoCAD Electrical Forum
Quick Access Toolbar
4 REPLIES 4
rkinsey
595 Views, 4 Replies
My quick access toolbar disappears for no reason. I set it up, save my workspace, make sure that everything is locked. I close ACADE, open it at a later date and all my quick access icons are gone with the exception of the open and new page icons.
 Anyone else have this problem and is there anything that can be done? My thanks in advance.
Richard
4 REPLIES 4
KevinLi-Autodesk
in reply to: rkinsey
Call command MENU in command line and reload acade.cuix to check if QAT comes back.
Kevin Li
Kevin-Hongyuan Li
Software Quality Assurance Engineer
Design, Lifecycle and Simulation Product Group
Direct: +86 21 2039 6025
Email: Hongyuan.Li@autodesk.com
Autodesk, Inc.
NO. 130, Lane 91, E Shan Rd
Building 12, Floor 6,
Shanghai 200127, PRC
www.autodesk.com
Icemanau
Is that with a new dwg or is it without a dwg?
I've noticed that if all dwgs are closed, the only menu/tool bars that are available are the ones you mentioned.
Regards Brad
Brad Coleman, Electrical Draftsman
KevinLi-Autodesk
in reply to: Icemanau
That is with a dwg.
Kevin Li
Kevin-Hongyuan Li
Autodesk, Inc.
www.autodesk.com
rkinsey
All, this happens with an open drawing/project. The quick access tool bar as well as the ribbon (set the size and it gradually widens). My ribbon is docked on the right side of my screen w/autohide on. Just small things that make you go hummm
”Boost
