3. This is a know problem with some printer drivers. Try updating the
printer driver. Check
http://discussion.autodesk.com/search.jspa?q=wipeout%20black&objID=f30&numResults=25&rankBy=9&source=viewforum%7C30
for more info.
5. The properties palette actally shows all the attributes that the selected
blocks has in common. Just scroll down to see them.
6. Try putting those lines on a "non-wire-layer" You'll see them in the
drawing, but AutoCAD Electrical won't try to work with them.
7. Can't you use the normal AutoCAD Dim-Leader? No circle around the text,
but...
THL
Trond Hasse LieAutoCAD Electrical and
EPLAN expert
Ctrl Alt ElPlease select "Accept Solution" if this post answers your question. 'Likes' won't hurt either.
