Hi
When I run the Reports command and put on the drawing,the field justification I selected the "Middle Left",everyting is OK.just a little problem is that the first letter is too closed to the left borders,when I print the drawing,is likely that missing the first letter.Can anyone help me?
In the Table Style format dialog box, under the General tab, look for the Margins box. Increase the value in the horizontal/vertical and the text will move to the correct position. Be aware that you will have to do this for all three cell styles (Title, Header, Data).
If you set this in your Template, it should be available on any further new dwgs. You will need to adjust this on any existing dwgs though.
Regards Brad
Icemanau (NNTP handle: Brad Coleman
AutoCAD Electrical User and IT Hardware Support
