Hi there fellow ACADE users.
I´m using ACADE2012 and I´m trying to find a function that updates description text of child symbols project wide.
I´m sure this function is incorporated in the software but I cant find it somehow??
Any hints apprecitated.
Regards, Gary
Solved by bholle. Go to Solution.
Are you thinking of the Child Location/Description Update command located in the Edit Components Panel under the Schematics tab on the ribbion? It is located in the drop down under Component Cross-Reference button. The command is AECHILDLOCUPDATE.
