I know we can Batch Plot project wide DWF directly from ACAD E, but is there any functionality where we can do the same for PDF .
Autocad Electrical 2012
regards
Ray
There are a number of ways to do this,
I tend to use:
Right click on the active project - choose publish - plot project select all drawings
Set the printer as Acade DWG to PDF, tick the plot to file box and specify the destination folder in the adjacent box.
There is also DWG to PDF and if you have a PDF creation program installed then you can plot to that as well - you may need to set up a page plot and save a .pc3 file for you to find in the publish settings.
Regards
David
Hello!!!
Sorry!!! Is possible to make or configure a hyperlink between sheet/drawings, take in account a cross references or child/parent association when I plot a project drawing in pdf format?
Randolf
As far as I know, the answer to that is no.
ACE uses a scratch database to handle all the project links. There is no way to embed this into a pdf.
I don't remember if it is present in ECADE 2012 but in 2013 you can click on the ACAD symbol in top right and left click on publish. Under teh Publish to drop down selection choose PDF. From there you can add dwgs to your sheet list and remove drawings. Just click the + or - symbol in the top left corner o fteh sheet list box and browse to the drawings you want to print. In the "Publish Options" selection you can designate a location where you want the PDF saved to. Also in this same menu you can select select Single Sheet File or Mulitsheet file. This will determine if each drawing is an individual PDF or if all your drawings are one PDF file with muliple pages. We use this all the time to package our projects into PDF documents for our customer submittals and for online downloads of project packages. You may need to play with it a few times to get all the little issues figured out but it works better than "Publish - Plot Project" Because it does all of it in the background while you work on something else as well as doesn't have to open each file and prompt for name. The thing I like best over the Plot Project command is the Multisheet file option so I don't have to go package all teh drawings together into one package after they are printed to pdf.
Autodesk might consider making this possible.
My company is looking at Eplan which can do this (its a loop of hyperlinks but at least you can surf in the pdf it creates).
I am not saying this is the main driver for making a decision to switch to Eplan... but... if someone else can do it Autodesk should be able to figure it out.
