AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Project-Wide Utilities/Script Problem ACE 2015
2 REPLIES 2
Tee.Dee
365 Views, 2 Replies
I am trying to run a simple script which freezes a layer for every selected drawing in a project by using the Project-Wide Utilities.
It appears to get stuck and not move to the next drawing but if you wait it is actually taking 1 minute to move on to the next drawing.
Worked fine on previos versions. Can anyone else confirm this behavior?
Thanks.
2 REPLIES 2
ccad2509
in reply to: Tee.Dee
post the script so i can try  i use a similar script
_CLAYER
0
_LAYER
OFF
xxxxx
xxxx being the layer you want to switch of
Tee.Dee
in reply to: ccad2509
_.-layer
_F
*DRAFT*
”Boost
