AutoCAD Electrical Forum
Problems with inserting components
3 REPLIES 3
366 Views, 3 Replies
Windows XP SP2
ACADE 2008 SP1
Problem :
Inserting various components into schematic fail to bring up the component
edit window.
This is happening across various components, while others are not affected.
Have tried deleting PROJECT database file and rebuilding. Also tried
restarting system.
Only happens in 1 project at this stage and started in the middle of a
session.
All command traces were on dwgs that had just been opened within the
project.
Output of command window with command trace turned OFF (from opening dwg to
end of command)
Opening an AutoCAD 2000 format file.
Regenerating layout.
Regenerating model.
AutoCAD Express Tools Copyright © 2002-2004 Autodesk, Inc.
AutoCAD menu utilities loaded.
AutoCAD Electrical menu utilities loaded.
Autodesk DWG. This file is a TrustedDWG last saved by an Autodesk
application
or Autodesk licensed application.
Command:
Command: _.TILEMODE
Enter new value for TILEMODE <0>: 1 Regenerating model.
Command:
Command:
Command:
Command:
Specify insertion point:
reading project database file...
Error: divide by zero_.UNDO Current settings: Auto = On, Control = All,
Combine
= Yes
Enter the number of operations to undo or [Auto/Control/BEgin/End/Mark/Back]
<1>: _END
Command:
Command:
Command:
Command: _copyclip
Output from command window with command trace turned ON
Regenerating model.
application
Command:
Command:
Command:
Command:
IN:wd_load
OUT:wd_load
Command: debug trace ON
Command:
Command: _.TILEMODE
Command:
Command:
Command:
IN:wd_load
OUT:wd_load
IN:wd_menu_load_schem
IN:wd_menu_wdmenu2use
IN:wd_wdp_get_proj_file_lsts
wd_1a_gn_getenv N;10;;WHT PRIM PROT CT;A=nil
OUT:wd_wdp_get_proj_file_lsts
OUT:wd_menu_wdmenu2use=ACE_IEC_MENU.DAT
OUT:wd_menu_load_schem
Command:
IN:wd_insym_dlg
IN:wd_sym_prelims
IN:wd_1
IN:wd_1_reset_dwg
IN/OUT:wd_wpnt_reset_sym_pntlst_cache
IN/OUT:wd_wpnt_reset_sym_pntlst_quik_cache
OUT:wd_1_reset_dwg
IN:wd_1_set_GBLs_from_env_settings
wd_1a_gn_getenv WD=c:/program files/autodesk/acade 2008/support/
wd_1a_gn_getenv WD_CAT=C:/Documents and Settings/colemanb/My
Documents/AcadE
2008/AeData/catalogs/
wd_1a_gn_getenv WD_SUP_ALT=nil
wd_1a_gn_getenv WD_PNL=j:/autocad/blocks/panel/
wd_1a_gn_getenv WD_USER=j:/autocad/blocks/
wd_1a_gn_getenv WD_SAVE2FILEDLG=nil
wd_1a_gn_getenv
WD_LIB=j:/autocad/blocks/jic125;j:/autocad/blocks/pneu_iso125;j:/autocad/blocks/
pid;j:/autocad/blocks/hyd_iso125/
OUT:wd_1_set_GBLs_from_env_settings
IN:wd_wdp_set_proj_globals
IN:wd_wdp_set_plus[]_settings
OUT:wd_wdp_set_plus[]_settings
OUT:wd_wdp_set_proj_globals
IN:wd_wdp_is_active_in_proj
IN:wd_wdp_get_projfile_lsts
OUT:wd_wdp_get_projfile_lsts
OUT:wd_wdp_is_active_in_proj
chk
OUT:wd_1
IN:wd_cfg_read_dwg_params
IN:wd_cfg_set_dwg_sort_mode=5
OUT:wd_cfg_set_dwg_sort_mode=
IN:wd_1_set_scl_factor
OUT:wd_1_set_scl_factor=0.75
IN:wd_wdp_get_proj_file_libpath
OUT:wd_wdp_get_proj_file_libpath
Panel Icon menu: ACE_PANEL_MENU.DAT
OUT:wd_cfg_read_dwg_params
OUT:wd_sym_prelims
IN:wd_wdmenu
IN:wd_fio_does_file_exist (ACE_IEC_MENU.DAT)
IN:wd_fio_chk_exist_usr_prj=ACE_IEC_MENU.DAT
wd_1a_gn_getenv WD_ACADPATHFIRST=nil
OUT:wd_fio_chk_exist_usr_prj
OUT:wd_fio_does_file_exist=C:\Documents and Settings\colemanb\Application
Data\Autodesk\AutoCAD Electrical 2008\R17.1\enu\Support\ACE_IEC_MENU.DAT
OUT:wd_wdmenu
IN:wd_sym_do_menu_select
sym to look for=VT0002
sym nam found=VT0002
IN:wd_sym_xxinsert_sym2
IN:wd_sym_ins_elect_blk_pause =VT0002
OUT:wd_sym_ins_elect_blk_pause
IN/OUT:wd_lay_adjust_attrib_layers
IN:wd_sym_connect_annotate
IN:wd_inwire_check_if_need_dot
OUT:wd_inwire_check_if_need_dot
IN:wd_sym_connect_annotate_try2
IN:wd_wpnt_trim_wires_at_points
IN:wd_wpnt_get_sym_pntlst_passby
OUT:wd_wpnt_get_sym_pntlst_passby
OUT:wd_wpnt_trim_wires_at_points
IN:wd_fio_does_block_exist_disk
OUT:wd_fio_does_block_exist_disk
IN:wd_sym_insert_elect_block J:\Autocad\Blocks\as2\HT0002.dwg
OUT:wd_sym_insert_elect_block
OUT:wd_sym_connect_annotate_try2
IN:wd_wpnt_get_sym_pntlst=
IN/OUT:wd_1_get_attr_ename attr=NO = nil
IN/OUT:wd_1_get_attr_ename attr=NC = nil
IN:wd_sed_edit_this_component
IN:wd_sed_is_it_schem_or_pnl
IN:wd_sed_get_comp_attr
IN/OUT:wd_4_selsort
OUT:wd_sed_get_comp_attr
IN/OUT:wd_1_get_attr_val h=7A08 nam=TAGSTRIP =
OUT:wd_sed_is_it_schem_or_pnl=7
IN/OUT:wd_4_selsort
IN/OUT:wd_1_get_attr_val h=7A08 nam=POS? = nil
IN/OUT:wd_1_get_attr_val h=7A08 nam=STATE = nil
IN/OUT:wd_1_get_attr_val h=7A08 nam=MFG =
IN/OUT:wd_1_get_attr_val h=7A08 nam=LOC =
IN/OUT:wd_1_get_attr_val h=7A08 nam=INST =
IN/OUT:wd_1_get_attr_val h=7A08 nam=CAT =
IN/OUT:wd_1_get_attr_val h=7A08 nam=ASSYCODE =
IN/OUT:wd_1_get_attr_val h=7A08 nam=WDBLKNAM = nil
IN/OUT:wd_1_get_pnlval ITEM = nil
IN:wd_sed_get_comp_rating_lst
OUT:wd_sed_get_comp_rating_lst
IN:wd_term_anno_term
IN:do_term_extract
IN:wd_term_term_extract
IN:wd_mdb_get_terms
IN/OUT:wd_mdb_proj_dbfnam=j:\autocad\blocks\HELENSVILLE - ERGO DWGS.mdb
IN:wd_mdb_create_ifreqd
OUT:wd_mdb_create_ifreqd
IN:wd_mdb2_upd_prj_ixlst
IN:ace_proj_data
OUT:ace_proj_data
IN:wd_mdb_make_ixlst_visible
OUT:wd_mdb_make_ixlst_visible
OUT:wd_mdb2_upd_prj_ixlst
OUT:wd_mdb_get_terms
IN:wd_term_extract_term_dwg
IN:wd_1_get_gridrefs
OUT:wd_1_get_gridrefs
OUT:wd_term_extract_term_dwg
IN:wd_term_do_trms
OUT:wd_term_do_trms
IN/OUT:wd_4_selsort
IN:wd_term_term_strip_nams
IN:wd_dsp_quadsort=(1 4 5 6)
IN/OUT:wd_4_selsort
OUT:wd_dsp_quadsort
OUT:wd_term_term_strip_nams
OUT:wd_term_term_extract
OUT:do_term_extract
IN/OUT:wd_1_get_attr_val h=7A08 nam=_TAG* = nil
IN/OUT:wd_1_get_attr_val h=7A08 nam=TERM* =
IN/OUT:wd_1_get_pnlval LTOTAL = nil
IN/OUT:wd_1_get_pnlval LNUMBER = nil
IN/OUT:wd_1_mod_attr_no_upd LINKTERM val= rtrn=1
IN:wd_term_gather_associated_terms
IN:wd_esym_err
Combine
= Yes
<1>: _END
Command:
IN/OUT:wd_dbase_releaseallhandles
OUT:wd_esym_err
Command:
Ouput of command window with MDB Command Trace ON
Regenerating model.
application
Command:
Command:
Command:
Command:
IN:wd_load
OUT:wd_load
Command: MDB debug ON
Command:
Command: _.TILEMODE
Command:
Command:
Command:
IN:wd_load
OUT:wd_load
Command:
IN:wd_insym_dlg
IN:wd_sym_prelims
IN:wd_1
IN:wd_1_reset_dwg
OUT:wd_1_reset_dwg
Documents/AcadE
wd_1a_gn_getenv
chk
OUT:wd_1
OUT:wd_sym_prelims
IN:wd_wdmenu
OUT:wd_wdmenu
IN/OUT:wd_4_selsort
IN/OUT:wd_1_get_attr_val h=7A83 nam=TAGSTRIP =
IN/OUT:wd_4_selsort
IN/OUT:wd_1_get_attr_val h=7A83 nam=POS? = nil
IN/OUT:wd_1_get_attr_val h=7A83 nam=STATE = nil
IN/OUT:wd_1_get_attr_val h=7A83 nam=MFG =
IN/OUT:wd_1_get_attr_val h=7A83 nam=LOC =
IN/OUT:wd_1_get_attr_val h=7A83 nam=INST =
IN/OUT:wd_1_get_attr_val h=7A83 nam=CAT =
IN/OUT:wd_1_get_attr_val h=7A83 nam=ASSYCODE =
IN/OUT:wd_1_get_attr_val h=7A83 nam=WDBLKNAM = nil
IN:do_term_extract
IN:wd_mdb_get_terms
IN:ace_proj_data
OUT:ace_proj_data
IN:wd_term_do_trms
OUT:wd_term_do_trms
IN/OUT:wd_4_selsort
IN/OUT:wd_4_selsort
OUT:wd_dsp_quadsort
OUT:do_term_extract
IN/OUT:wd_1_get_attr_val h=7A83 nam=_TAG* = nil
IN/OUT:wd_1_get_attr_val h=7A83 nam=TERM* =
IN:wd_esym_err
Combine
= Yes
<1>: _END
Command:
OUT:wd_esym_err
Command:
Regards Brad
3 REPLIES 3
Brad, is this only for terminals or other types of components? The part
where it is getting the error seems specific to terminals. Can you send me a
drawing to try it on? Does it happen to the first terminal inserted in the
session or just subsequent terminals? What I mean here is can you start
AcadE and insert a terinal and it come in fine, then insert another and it
gets the error? pat.murnen@autodesk.com
Pat
"Brad Coleman" wrote in message
news:5945615@discussion.autodesk.com...
Windows XP SP2
ACADE 2008 SP1
Problem :
edit window.
restarting system.
session.
project.
end of command)
Regenerating model.
application
Command:
Command: _.TILEMODE
Command:
Command:
Command:
Command:
Combine
= Yes
<1>: _END
Command:
Command:
Command:
Command: _copyclip
Regenerating model.
application
Command:
Command:
Command:
Command:
IN:wd_load
OUT:wd_load
Command:
Command: _.TILEMODE
Command:
Command:
Command:
IN:wd_load
OUT:wd_load
Command:
IN:wd_insym_dlg
IN:wd_sym_prelims
IN:wd_1
IN:wd_1_reset_dwg
OUT:wd_1_reset_dwg
Documents/AcadE
wd_1a_gn_getenv
chk
OUT:wd_1
OUT:wd_sym_prelims
IN:wd_wdmenu
OUT:wd_wdmenu
IN/OUT:wd_4_selsort
IN/OUT:wd_4_selsort
IN:do_term_extract
IN:wd_mdb_get_terms
IN:ace_proj_data
OUT:ace_proj_data
IN:wd_term_do_trms
OUT:wd_term_do_trms
IN/OUT:wd_4_selsort
IN/OUT:wd_4_selsort
OUT:wd_dsp_quadsort
OUT:do_term_extract
IN:wd_esym_err
Combine
= Yes
<1>: _END
Command:
OUT:wd_esym_err
Command:
Regenerating model.
application
Command:
Command:
Command:
Command:
IN:wd_load
OUT:wd_load
Command:
Command: _.TILEMODE
Command:
Command:
Command:
IN:wd_load
OUT:wd_load
Command:
IN:wd_insym_dlg
IN:wd_sym_prelims
IN:wd_1
IN:wd_1_reset_dwg
OUT:wd_1_reset_dwg
Documents/AcadE
wd_1a_gn_getenv
chk
OUT:wd_1
OUT:wd_sym_prelims
IN:wd_wdmenu
OUT:wd_wdmenu
IN/OUT:wd_4_selsort
IN/OUT:wd_4_selsort
IN:do_term_extract
IN:wd_mdb_get_terms
IN:ace_proj_data
OUT:ace_proj_data
IN:wd_term_do_trms
OUT:wd_term_do_trms
IN/OUT:wd_4_selsort
IN/OUT:wd_4_selsort
OUT:wd_dsp_quadsort
OUT:do_term_extract
IN:wd_esym_err
Combine
= Yes
<1>: _END
Command:
OUT:wd_esym_err
Command:
Regards Brad
Hi Pat
I've had it happen to other components as well. Fuses and links I know
have the same problem. Also noticed after sending the post yesterday,
that some 3 pole items are affected as well.
I believe it's to do with the project and will send it to you as soon as I
can get it zipped.
Regards Brad
"Pat Murnen" wrote in message
news:5945805@discussion.autodesk.com...
Pat
Windows XP SP2
ACADE 2008 SP1
Problem :
edit window.
restarting system.
session.
project.
end of command)
Regenerating model.
application
Command:
Command: _.TILEMODE
Command:
Command:
Command:
Command:
Combine
= Yes
<1>: _END
Command:
Command:
Command:
Command: _copyclip
Regenerating model.
application
Command:
Command:
Command:
Command:
IN:wd_load
OUT:wd_load
Command:
Command: _.TILEMODE
Command:
Command:
Command:
IN:wd_load
OUT:wd_load
Command:
IN:wd_insym_dlg
IN:wd_sym_prelims
IN:wd_1
IN:wd_1_reset_dwg
OUT:wd_1_reset_dwg
Documents/AcadE
wd_1a_gn_getenv
chk
OUT:wd_1
OUT:wd_sym_prelims
IN:wd_wdmenu
OUT:wd_wdmenu
IN/OUT:wd_4_selsort
IN/OUT:wd_4_selsort
IN:do_term_extract
IN:wd_mdb_get_terms
IN:ace_proj_data
OUT:ace_proj_data
IN:wd_term_do_trms
OUT:wd_term_do_trms
IN/OUT:wd_4_selsort
IN/OUT:wd_4_selsort
OUT:wd_dsp_quadsort
OUT:do_term_extract
IN:wd_esym_err
Combine
= Yes
<1>: _END
Command:
OUT:wd_esym_err
Command:
Regenerating model.
application
Command:
Command:
Command:
Command:
IN:wd_load
OUT:wd_load
Command:
Command: _.TILEMODE
Command:
Command:
Command:
IN:wd_load
OUT:wd_load
Command:
IN:wd_insym_dlg
IN:wd_sym_prelims
IN:wd_1
IN:wd_1_reset_dwg
OUT:wd_1_reset_dwg
Documents/AcadE
wd_1a_gn_getenv
chk
OUT:wd_1
OUT:wd_sym_prelims
IN:wd_wdmenu
OUT:wd_wdmenu
IN/OUT:wd_4_selsort
IN/OUT:wd_4_selsort
IN:do_term_extract
IN:wd_mdb_get_terms
IN:ace_proj_data
OUT:ace_proj_data
IN:wd_term_do_trms
OUT:wd_term_do_trms
IN/OUT:wd_4_selsort
IN/OUT:wd_4_selsort
OUT:wd_dsp_quadsort
OUT:do_term_extract
IN:wd_esym_err
Combine
= Yes
<1>: _END
Command:
OUT:wd_esym_err
Command:
Regards Brad
Per our emails - after looking at the drawings you sent directly to me it
appears that there is no vertical value in the X-Y Grid setup. To correct
this go in to the Drawing Properties for the drawings and add a Vertical
Value (Drawing Properties -> Drawing Format tab -> Format Referencing
Setup).
Pat Murnen
news:5946541@discussion.autodesk.com...
Hi Pat
can get it zipped.
Regards Brad
Pat
Windows XP SP2
ACADE 2008 SP1
Problem :
edit window.
restarting system.
session.
project.
end of command)
Regenerating model.
application
Command:
Command: _.TILEMODE
Command:
Command:
Command:
Command:
Combine
= Yes
<1>: _END
Command:
Command:
Command:
Command: _copyclip
Regenerating model.
application
Command:
Command:
Command:
Command:
IN:wd_load
OUT:wd_load
Command:
Command: _.TILEMODE
Command:
Command:
Command:
IN:wd_load
OUT:wd_load
Command:
IN:wd_insym_dlg
IN:wd_sym_prelims
IN:wd_1
IN:wd_1_reset_dwg
OUT:wd_1_reset_dwg
Documents/AcadE
wd_1a_gn_getenv
chk
OUT:wd_1
OUT:wd_sym_prelims
IN:wd_wdmenu
OUT:wd_wdmenu
IN/OUT:wd_4_selsort
IN/OUT:wd_4_selsort
IN:do_term_extract
IN:wd_mdb_get_terms
IN:ace_proj_data
OUT:ace_proj_data
IN:wd_term_do_trms
OUT:wd_term_do_trms
IN/OUT:wd_4_selsort
IN/OUT:wd_4_selsort
OUT:wd_dsp_quadsort
OUT:do_term_extract
IN:wd_esym_err
Combine
= Yes
<1>: _END
Command:
OUT:wd_esym_err
Command:
Regenerating model.
application
Command:
Command:
Command:
Command:
IN:wd_load
OUT:wd_load
Command:
Command: _.TILEMODE
Command:
Command:
Command:
IN:wd_load
OUT:wd_load
Command:
IN:wd_insym_dlg
IN:wd_sym_prelims
IN:wd_1
IN:wd_1_reset_dwg
OUT:wd_1_reset_dwg
Documents/AcadE
wd_1a_gn_getenv
chk
OUT:wd_1
OUT:wd_sym_prelims
IN:wd_wdmenu
OUT:wd_wdmenu
IN/OUT:wd_4_selsort
IN/OUT:wd_4_selsort
IN:do_term_extract
IN:wd_mdb_get_terms
IN:ace_proj_data
OUT:ace_proj_data
IN:wd_term_do_trms
OUT:wd_term_do_trms
IN/OUT:wd_4_selsort
IN/OUT:wd_4_selsort
OUT:wd_dsp_quadsort
OUT:do_term_extract
IN:wd_esym_err
Combine
= Yes
<1>: _END
Command:
OUT:wd_esym_err
Command:
Regards Brad
”Boost
