Hi there,
I have a strange problem when inserting multiple cablemarkers. The problem occurs only if or when the first conductor which also holds the parent symbol is different from the first number defined in the pinlist for the cable in question.
I have no problems inserting the cable and ACADE fetches the pinlistvalues going from 1,2,3,4...etc,
However if i go and edit the conductors manuallly such that conductor previously defined no.1 is numered 17 and conductor previously defined no.2 is numbered 18 and following conductors get numered 1,2,3,4,5,6,7,8 (see attached image) strange things happen. For some reason this action causes the parent conductor to lose somehow connectivity with the database such that catalog information already defined in the one line schematics are not inherited.
Any comments greatly appreciated.
Regards, Gary
Hi Gary.
If you rebuild the database.. Do it "reconnect"?
Hello Rhesusminus,
I´ll give it a try tomorrow to see if it reconnects after a rebuild.
Thanks again for looking into this.
Regards, Gary
