You can try this: you can force your report
to generate the old way (scans dwgs to update scratch database) by typing
this at command line: (wd_pds_set_fromto nil) [press enter] and making sure
that you're instructed AcadE to do a full rebuild including wire
connections. See if this gets past this problem with the AIP wire list.
To return to normal operation, type this at command line:
(wd_pds_set_fromto T) [press enter]
Let me know if this gets you past this issue.
thanks,
Nate.
wrote in message news:4989831@discussion.autodesk.com...
I try to create AIP Wire List report from schematic with fan in/out cable
marker but the Cable ID and Conductor ID columns in report are still empty.
I use ACE 2006 without any SP but with SP1 and SP2 are still the same.
What's going on?
