Have there been any improvements to this yet?
I have been able to embed the Source and Load XDATA values into my existing symbols but am having trouble with the Pass Component XDATA. That appears to be tied to the block after insertion.
Has anyone come up with a way to embed this in the symbol drawing??
Also, the Pass Component appears to only work if the symbol has only two terminals. Is this correct? I have developed a symbol with 6 terminals and the Pass Component does not work.
Upon further research, it appears that the Power Check does not folllow Source/Destination arrows from page to page.
In the WDDEMO project, I set up sources on Page 2 and then set up loads on Page 3 and these loads where not counted during the Load Check Report but the loads on Page 2 were.
I am using 2013 so maybe it used to work.
I am a bit dissapointed. This feature would have been really useful in circuit design. A pity. Looking back, this feature has been in the product since 2005 and it still does not work effectively.
Someone really dropped the ball on this one...
This function struggles with 3 phase non symmetrical loads or as you mentioned following the circuitry but in my example it does not even follow wiring on one page. It must be a problem with passing of the power/signal through devices or child components or issue with pass power flags.
Also it is problematic to check power of dc circuits especially containing PLC with I/O modules
Not many people are interested in this subject and issues are pretty obvious. Is it better to avoid this function within acad.
