Tracy,
No, the problem is not plines etc.
I have also posted the question to the print/plot discussion group and to HP
forums.
In the course of troubleshooting this problemI have discovered that I cannot
applies the 2004 service pack to AutoCAD electrical. I get an error message
indicating that the expected product cannot be found on my computer. The
automatic updating says it is up-to-date eventhough the version is 2004.0.0
service pack 0.
Jens
"Tracy W. Lincoln" wrote in message
news:40643119$1_1@newsprd01...
> Speaking from a purely AutoCAD standpoint...and without seeing the DWG &
CTB
> here are a few things to check.
> I would check to see if those are not plines with widths applied (ignoring
> the lineweights applied in the CTB) if so then either PEDIT them to all
have
> a 0 width... or check to see if a lineweight was applied to the layer
which
> they reside.
> In addition to any of the replies already received, you may find more
> information or responses by posting future print related questions in the
> print/plot discussion group.
> NNTP discussion group readers use
> news://discussion.autodesk.com/autodesk.autocad.print-plot
> HTTP web-based group uses
> http://discussion.autodesk.com/forum.jspa?forumID=30
> Tracy W. Lincoln
> Autodesk Discussion Group Facilitator
> http://www.autodesk.com/discussion-announcements
> "Jens Jensen" wrote in message
> news:406428ec_1@newsprd01...
> > I have not been able to make AutoCAD electrical 2004 plot correctly to
my
> HP
> > DesignJet 500. I have the latest HP drivers. I am running Windows XP
> Pro.
> > My customer forces me to use CTB files. The plotted files looked as if
> > printer driver is not interpreting the CTB file correctly. only a few
> lines
> > will appear to have correct line widths. Most of the lines are plotting
> at
> > a minimum line with, ignoring the line widths set in the CTB file. I
have
> > tried creating a new CTB file, where every color has the same line
widths,
> > but that does not work either. The CTB file works fine with AutoCAD 2000
> and
> > the same HP driver.
> > Jens Jensen
