AutoCAD Electrical Forum
Plotting problems
2 REPLIES 2
155 Views, 2 Replies
Plotting problems
I am having problems plotting from AE 2007 to our HP DesignJet 500. Sometimes it prints the entire drawing, sometimes it does not. It seems like the plotter doesn't spool or receive the entire file before beginning to plot. The border always prints without any problems, but it is the content of the drawing that is intermittently plotted. For example, the plot was sent a total of 3 times, each time waiting a few minutes between plots. On the last attempt, the plot was printed correctly.
The plotter is connected to the network and is managed by our network file and printer server running Windows 2000 SP4. I understand this may be an HP or Microsoft problem, but I am just trying to cover all the bases including potential AutoDesk issues.
Any suggestions would be greatly appreciated.
Matt
2 REPLIES 2
hi matt
pl use the script...replace the exisitng printer with your printer name with the path
-PLOT
Y
Model
\\Printer\HP LaserJet 3300 Series PCL 6 (change to ur printer name)
A4
Inches
Landscape
No
Extents
Fit
Center
Y
monochrome.ctb
Y
A
N
Y
Y
save this as .scr file and use project pull down menu and in that select "project wide utilities" and and select "run command script file" under "for each drawing".. select the .scr file..
hope this helps
sathya
for ur cad outsourcing needs..
satya.nk@control-infotech.com
Sathya -
Thanks very much for the response and the info above. Unfortunately, it did not solve my problem. Are there any other ideas you might have ?
Thank you.
Matt
”Boost
