Hello, last week I was trying to do a mass plot of a project, and came across this problem. Upon setting up the plot, nothing happens. I get this in the command line:
Last plot's settings retrieved from C:\Users\Nick
Merrill\AppData\Roaming\Autodesk\AutoCAD Electrical
2011\R18.1\enu\Support\user\lastplot.tmp
_.ACE_SCRIPT C:/Users/Nick Merrill/AppData/Roaming/Autodesk/AutoCAD Electrical
2011/R18.1/enu/Support/user/_WDPLOT.SCR
Command:
Command: (COMMAND "_.SCRIPT" "C:/Users/NICKME~1/AppData/Local/Temp/ace4FF6.scr")
_.SCRIPT
Enter script file name <C:\users\nick
merrill\documents\projects\upstate\upstate recycling mill 555\cad drawings\CP-1
ENCLOSURE DETAIL.scr>: C:/Users/NICKME~1/AppData/Local/Temp/ace4FF6.scr
Command: nil
Command: _.cmdecho
Enter new value for CMDECHO <1>: 0
Command: wd_scr_msg "========== Drawing 1 of 4 =========="
Command:
Command: wd_prnt_time_date
Searching BLOCK table for attibute "WD_TB". . . Found. Title block=ACADE_TITLE
Found. Title block=NO_NUM_acade_title Found. Title block=Upstate Template
Command: _.-PLOT
Detailed plot configuration? [Yes/No] <No>: _YES
Enter a layout name or [?] <Model>: 'wd_chk4_layoutnam_oem "Model"
"Model"
Enter an output device name or [?] <Adobe PDF>:
Enter paper size or [?] <Letter>: Adobe PDF
Command:
'WD_CHK4_LAYOUTNAM_OEM Landscape
"Model"
Command:
Command:
'WD_CHK4_LAYOUTNAM_OEM _E
"Model"
Command:
Command: _F
Unknown command "F". Press F1 for help.
Command:"
I have used this plot method many times, and as far as I can tel I have not changed any settings. I can plot the pages individually, but that takes quite a while in a 150+ page project. Thanks in advance, Nick.
