AutoCAD Electrical Forum
Plot Project Autocad 2011
3 REPLIES 3
RomGY
258 Views, 3 Replies
Hallo I print a project via Plot Project. Problem: I have Portrait and Landscape pages mix in the Project. Now, all Landscape page must by print in upside-down In the Page plot dialog box, i have select upside-down. In 'Batch Plotting Option and Order - Detailed Plot Configuration Option' under 'Misc settings' 'default' is selected. But the printout isn't upside-down, and i must turn the page by hand... Anybody have a solution for my???
3 REPLIES 3
sonny3g
in reply to: RomGY
Try using the Plot/Publish command instead.  As long as you have your pagesetup created in each of the drawings that need a unique method of plotting you can get what you want for each sheet and still plot it as a batch.  Here is a short video on using batch plot/publish in ACADE.
http://youtu.be/e9kO3lPlJB4
Scott G. Sawdy
scott.sawdy@bluecoyotecad.com
RomGY
in reply to: RomGY
Hallo Thanks for your quick answer. I have test Batch Plot, but it is not the right for me. I use different Plotter with different paper size. Plot Project is ok, but only the upside-down for landscape sheets is not ok. It "Detail Plot Configuration Option" it is set to default. But what means default, from where comm the default value? Greats
dougmcalexander
in reply to: RomGY
I would suggest that you use page setup for each drawing that is not plotting correctly. You can set paper size, plot extents, center plot, orientation, etc. I do this in my drawing template so all new drawings are already set.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
”Boost
