AutoCAD Electrical Forum
Peer tot Peer link possible with Terminals?
3 REPLIES 3
JEeten
902 Views, 3 Replies
Hi all,
It is possible to link components (electric-hydraulic) so if one tag is changed the other linked compnenttag changes also. Does anybody knows a way to do the same with terminals and coils (relay)?
Using AutoCAD Electrical 2012.
Do I have to make new blocks with other family code or something like that?
John van Eeten
Tags (3)
3 REPLIES 3
dougmcalexander
in reply to: JEeten
It sounds like you may be dealing with protection relays, but I'm just guessing.  Managing a peer relationship between relay symbols is possible by using the WDTYPE attribute.  See the help menu for more details.  You will need to add this attribute to symbols that do not already contain it.  WDTYPE was added to support one-line diagram functionality, but other uses are possible.  The attribute value that signifies a one-line symbol is 1-, but you can use custom values, as long as you do not exceed 4 characters for the WDTYPE attribute value.  See the attached screen capture which explains how to manage a peer/duplicate relay coil.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
JEeten
in reply to: dougmcalexander
Thanks Doug,
I tried this and this is what I was looking for. Great!
Best Regards,
John
JEeten
in reply to: JEeten
With the relay coil this works, but not with terminals.
Do you know if this is possible?
Best Regards,
John
”Boost
