AutoCAD Electrical Forum
Parent/Sibling Child Component Project Wide look up frustration
9 REPLIES 9
Message 1 of 10
Dag_Henrik
908 Views, 9 Replies
Argh!
Why can't the Project Wide look up window in the Insert/Edit Child Component tab be re-sized?
This is very annoying when the descriptions gain some length, as in the attached image...
This is in autoCAD E 2012. Maybe it is fixed in 2014?
9 REPLIES 9
Message 2 of 10
rhesusminus
in reply to: Dag_Henrik
Hi Dag_Henrik.
I'm sorry to say that this hasn't been fixed in 2014 either.
And I belive it's quite a job to make this dialog resizeable as well, so don't get your hopes too hig for any newer release.
So, maybe this is a good time to swap the DESC1 & DESC 3-lines, so that the unique information is listed first in this dialog Smiley Surprised?
But i totally agree with you... It shouldn't have to be like that (Fra Lippo Lippi Smiley Very Happy!)
Trond Hasse Lie
AutoCAD Electrical and EPLAN expert
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Message 3 of 10
Dag_Henrik
in reply to: rhesusminus
Just had to whine a bit about it...
You are totally right about swapping DESC1 and DESC3, but still...
Sorry to hear it's not been fixed in 2014 either.
Thank you for your reply and awesome link Smiley Very Happy
Just what I needed on a Friday.
Message 4 of 10
vladop
Find file wdsym.dcl; I found it on this path C:\Program Files\Autodesk\AutoCAD 2014\Acade\Support\en-US
Make a backup copy of this file e.g. wdsym_original.dcl.
Open  wdsym.dcl in Notepad. In this file find row proj_comp_lst : dialog
That is definition of the dialog box.
49 rows below you should find following row:
key="cn_lst";width=95;height=20;allow_accept=true;tabs="2 28 39 60";   // 21-May-02 adjusted tabs
Increase width from 95 to e.g. 200 and save the file.
You can also increase height, or experiment with other elements of the dialog, but be sure that you saved a backup copy of the file.
Vladimir
Message 5 of 10
Dag_Henrik
in reply to: vladop
That did the trick!
Nice one!
Thank you a metric ton and have a nice weekend
Message 6 of 10
vladop
Thank you, it was problem for me too, but somehow I never took the time to solve it.
Message 7 of 10
drathak
in reply to: vladop
Nice!
So is the reason it would be hard to make it sizeable because that dialog is done in Diesel rather than .NET or something else more modern?
Joe Weaver
Principle Associate Engineer - Nashville Electric Service
P&C Committee Chair – SDS Industry Consortium
Message 8 of 10
rhesusminus
in reply to: drathak
Exactly Smiley Happy
Trond Hasse Lie
Ctrl Alt El
Message 9 of 10
vladop
DCL is dialog box definition for LISP.
If you want to know more follow this link:
http://www.afralisp.net/dialog-control-language/
Message 10 of 10
jdenny
As someone has already mentioned, there are DCL files to control all the GUI's and dialog boxes. You can search on the DCL files (which true to this application are spread all over the place) and do a considerable amount of customizing. It is not intuitive as to which batch of DCLs are controlling what, so be sure to use a good editor so you can quickly see the results of the changes you've made. I'm attempting to map them all out so I will be able to make the changes I need. If anyone else has already cross referenced these files, please let us know. Thanks.
Jeff Denny
Sr. Engineering Manager
Harris Corporation
Melbourne, Florida
”Boost
