AutoCAD Electrical Forum
Panel layout
3 REPLIES 3
425 Views, 3 Replies
Panel layout
For some reason, the procedure I am reading in the help section does not match what ACADE 2013 is doing.  For the panel layout;
"In the Schematic Component List -- Panel Layout Insert dialog box, verify:
Extract component list for: 
Project
Location Codes to extract: 
All
Click OK"
At this point, it looks like a new window should populate asking to select the drawings to process.  I am not getting this window as described in the help file.  The program just seems to timeout.  Am I missing something that is preventing me from selecting all of my drawings within my project to create this schematic list?
Thanks for any input!
Robert
3 REPLIES 3
testsubject
What you are expecting to see is what you should be seeing.
Did you use two screens but are using only one now? It may be that the dialog box is "Off screen". If this is the case, type ALT+SPACE and then  and then you will be able to use the arrow keys to move the dialog box around.
Bob Hanrahan
Ace User since 1998
If this answered your question, please click on "Accept Solution"
in reply to: testsubject
holy hell of a headache, that was easy....  thank you so much!
testsubject
No problem. You would not believe how often that has cropped up...
Bob Hanrahan
Ace User since 1998
”Boost
