The default for the panel footprints are folders under c:\program
files\autodesk\acade 200#\libs\panel. They are usually in folders by vendor
under this path. This is defined per project though. You can see this path
for a project if you right click on the project name and select Properties.
On the dialog that comes up, on the Project Settings tab, expand the Panel
Footprint Libraries to see the actual path or paths.
Hope this helps,
Pat Murnen
wrote in message news:5732749@discussion.autodesk.com...
I hope there is an easy answer for this. Where is the panel footprint
library? I can't find it anyplace. Does it actually exist or is it some
kind of parametric build. I'm looking for terminal block footprints
primarily.
