AutoCAD Electrical Forum
Page Numbers...?
7 REPLIES 7
Message 1 of 8
Aman
955 Views, 7 Replies
Page Numbers...?
Suppose my project consists of, say, 150 pages (drawings) and I have to enter a page after 100th drawing. Is there any way that i could change the whole page numbers written on each drawing automatically...?
7 REPLIES 7
Message 2 of 8
testsubject
in reply to: Aman
From the Projects dialog box, when you select "Update TBs" on that Dialog Box in the lower Right hand corner is a check box to resequence sheet numbers and you can enter a starting point.
Bob Hanrahan
Ace User since 1998
If this answered your question, please click on "Accept Solution"
Message 3 of 8
in reply to: Aman
There is also a "Project-wide Reseq/Retag" utility under Electrical/Project that will change the drawing number on all the drawings... Nothing in place to change the filenames, however. "testsubject" wrote in message news:13991133.1091536752679.JavaMail.jive@jiveforum2.autodesk.com... > From the Projects dialog box, when you select "Update TBs" on that Dialog Box in the lower Right hand corner is a check box to resequence sheet numbers and you can enter a starting point.
Message 4 of 8
testsubject
in reply to: Aman
To change the filename just add FILENAME to your attribute drawing and add FILENAME=Filename to your default.wdt file.
Bob Hanrahan
Ace User since 1998
Message 5 of 8
Aman
in reply to: Aman
Dear TS,
Thanks for your help,
But there is a tiny viny problem....
I am using Acad 2000.....
Do you have any solution for this updated problem?
Aman
Message 6 of 8
testsubject
in reply to: Aman
Since you are using ACAD 2000 which version of WD are you using? My guess it is Pre VIA. I was just looking in my ToolBOX WD Manual (1998) and resequencing Sheet numbers was not available then. With so many changes and improvements that have occurred over the years, I would recommend that you update to the most current release. It is really worth it. Do not get rid of your manual though. There is still a lot of pertinent info in it and Autodesk does not provide a paper manual.
Robert Hanrahan
Weigh Right Automatic Scale Co.
ACE user since 1998
Bob Hanrahan
Ace User since 1998
Message 7 of 8
Aman
in reply to: Aman
Thanks Robert,
I am using Windows XP.
Does Acad 2005 contains my solutions?
Aman
Message 8 of 8
testsubject
in reply to: Aman
Aman,
For what you are wanting to do, yes it does.Plus a whole lot more...
Robert Hanrahan
ACE user since 1998
Bob Hanrahan
Ace User since 1998
”Boost
