AutoCAD Electrical Forum
PLC split TAG
4 REPLIES 4
vladop
328 Views, 4 Replies
PLC split TAG
How can I position Tag attribute of the parametric PLC split part? Is there a file used for making split parts?
4 REPLIES 4
btackes
in reply to: vladop
Did you ever find an answer?  I was wondering the same thing.
vladop
in reply to: btackes
No, I still use Move Attribute command to position it.
testsubject
in reply to: vladop
Here is a Wiki on how to spilt a tag into two pieces.
To do this with the Parametric, you will have to go into the appropriate PLC component drawing and add these tags to it but it should be pretty painless. I recommend making copies of hte files before to make any changes.
http://wikihelp.autodesk.com/AutoCAD_Electrical/enu/2012/Help/0266-Symbol_L266/0271-Split_a_271
Bob Hanrahan
Ace User since 1998
If this answered your question, please click on "Accept Solution"
btackes
in reply to: vladop
The issue is not splitting the tag, it's splitting the PLC over multiple pages.  AutoCAD Electrical adds the tag to each section of the PLC and its these tags that we want to be able to position.  Unfortunately I cannot find any documentation on how the tag is added to subsequent sections of the PLC.  It's not part of the PLC database as far as I know.
”Boost
