Hi all,
In "Edit PLC Module" window when editing my fixed plc unit, there is only 1 pin assigned to particular addres - question is how to assign 2(or more) pins to a single IO address (for example when i want to define a relay output pins, that will be later automatically assigned to a stand-alone IO point on other drawings)?
(see attached image)
I've tried adding optional attributes to wire connection in symbol builder, and modifying wire connection style but it doesnt do the trick or i am doing somethin wrong.
I also noticed that when I inserted a stand alone point with 2 wire connections, then in window Edit PLC I/O Point -> List there are tables "pairs", "Unused (form-C)", "unused other" so I guess there is a possibility to define for example a Form-C relay output in fixed plc unit? Or am i wrong and it can't be done?
If you look at the PLC terminal block settings in the PLC database editor, such as HP1DWAWO or HP1DWAWC, they have relay type PLC outputs.
Once you insert the PLC on the drawing and edit the module, you can see the pins 1 and 2 desc but the pin 2 is grey out or not shown.
Maybe if you can figure out how to show the pin2, please let me know as well.
Hi all,
I managed to assign pins to a single I/O - the trick was to set terminals as right and left - so the I/O point is TAGA01, and the terminals are X1TERM01L (TERM01L) and X1TERM01R (TERM01R). (attachment 1)
EDIT: thanks for advice LionSG - it helped a lot.
Now the problem is that when I insert the stand-alone I/O point, and point to this I/O point it only extracts the 1st pin. I use the ACADE Block "IN,1s Point, 2 Wires" (PLCIOI2TV). (attachment 2)
"how to assign 2(or more) pins to a single IO address"
Well what you may be looking for may not be possible. One trick is to make the pin # description "1,2" instead of "1". It is crude but indicates that pins 1 and 2 are connected internally. I beleive some of the out-of-box PLC modules have this option.
Well, I actually managed to assign 2 pins to a single I/O point (see one of my previous post), but it doesn't work with stand-alone plc points (2nd pin number isn't transfered to a stand-alone plc point).
I did as you suggested and it worked partially.. When creating my fixed plc unit, I made pin number for an I/O point as "1 2", "3 4" and so on.
Then when i inserted my stand-alone plc point and linked it with my fixed plc unit, it worked good. (see attachment 1) Next fixed plc that I intented to use was the relay outputs relay module (Siemens TXM1.6R)...
And that is where I got really frustrated... I made the pin number as "3 2 4" to represent the 1 channel of relay output, and what I wanted to achieve you can see on attachement 2. What I got you can see on attachment 3. For some reasons ACADE (I use 2014), is cutting part of the terminal description.. instead of "3 2 4" i got "3 2 ". Any ideas?
In ACE 2018, 2019, 2020 and 2021 the connection between PLC fixed units and standalone 2 pins IO works!
This is only working in the same sheet. If you connect this between 2 sheets, it's only connecting 1 pin.
Why this doesn't work between 2 sheets is the question.
Kind regards,
Nam Ha
Hi
I confirm that the same thing happens to me too.
I would add that, working in the same sheet, the insertion takes place correctly but, if a change is made (a move or update of the Description fields), the change is not carried over to the child and vice versa
