I have made a spreadsheet that creates a PLC card, my problem is that the PLC card which is made has no Tag1, Desc1 values etc...
Is there anyway to add this to the block created so that I can get it to show up in component reports ?
For Desc1,2... you should be able to have those desc columns in your spreadsheet.
For the PLC tag, this is configured in the PLC database editor depend on which module code you are using.
You can take alook at the sample spreadsheet (demoplc.xls) to see how the configuration columns format should be.
Thanks I sorted it, had to go into PLC database editor and add a end type plc connector pin with all the attributes on it.
