Goto Project Properties --> Components and tick "Combined Installation/Location tag mode"
this will solve your issue with %S part.
Gerald
Thanks a lot, by checking that optiopn I was then able to select Pick from the edit PLC Module menu and "Pick" my source or destination links in the drawing as the "device to capture description text". I had tried to do the same thing before I checked the "Combined Installation/Location tag mode" in the Project Properties under the Components tab and it did not work. Thanks again!
Hi
Does anyone know where this can be found now? I have done quite a bit of searching and can't find it
Regards
John
Hello there,
I have attached an MHTML document with Nate´s post on this issue.
Regards, Gary
