AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
PLC Parametrics
1 REPLY 1
206 Views, 1 Reply
PLC Parametrics
What is the coding used for naming blocks for plc parametrics? I would like to make addtional blocks to be added to the first (5) groups.
1 REPLY 1
testsubject
This is the format for 99% of the dwgs that make up the PLC Parametric Build.
[pre]
12345678.dwg
1 - either (H)orizontal or (V)ertical
2 - P for PLC
3 - denotes the Style of PLC; 1,2,3,4,5...
From here it get a little tricky :0
For the rest of the positions, a dash (-) is used as a place holder
i.e., HP1--WLR.dwg
Based on this chart, this drawing would be Horizontal, PLC,
Style 1, , ,Wire comes from the right, Includes Module Info,
Terminal point located on the right.
4 - w-Wire comes from the left
D-Descriptions are on the left
5 - A-Input Address
w-Wire comes from the left(Used if D is in position 4)
6 - w-Wire comes from the right
A-Output Address
7 - D-Descriptions are on the right
L-Includes Module info: First point on the PLC Block.
w-Wire comes from the right(Used if D is in position 4)
8 - L-Includes Module info(Used if D is in position 7)
R-Terminal is located on left
Q-Terminal is located on right
O-Normally Open (NO) Output contact
C-Normally Closed (NC) Output contact
[/pre]
This makes up the bulk of the PLC I/O dwgs. There are a few special ones, but they are pretty unique. I hope this helps.
Robert Hanrahan
Weigh Right Automatic Scale Co.
ACE User since 1997
Bob Hanrahan
Ace User since 1998
If this answered your question, please click on "Accept Solution"
”Boost
