AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
PLC I/O SPREADSHEET MOD
3 REPLIES 3
twright
225 Views, 3 Replies
I have modified the wdio.dcl file to be able to insert more than the original (6) ladders per drawing. This works fine for module insertions but not for line reference numbers. Only (6) ladders receive the full line reference numbers with the remaining ladders receiving the first line number and the last line number per ladder. Is there a value in the wdio.lsp file that needs to change?
3 REPLIES 3
in reply to: twright
"tomw47" wrote in message news:14277243.1087586880690.JavaMail.javamailuser@localhost... > I have modified the wdio.dcl file to be able to insert more than the original (6) ladders per drawing. This works fine for module insertions but not for line reference numbers. Only (6) ladders receive the full line reference numbers with the remaining ladders receiving the first line number and the last line number per ladder. Is there a value in the wdio.lsp file that needs to change?
For the 7th through "nth" ladders, is the first line reference number correct? If so, with the drawing on screen, select the "revise ladder" command. Advance to the 7th ladder and start toggling the check boxes in the next to last column to "ON". See if this will regen missing line reference numbers. "tomw47" wrote in message news:14277243.1087586880690.JavaMail.javamailuser@localhost... > I have modified the wdio.dcl file to be able to insert more than the original (6) ladders per drawing. This works fine for module insertions but not for line reference numbers. Only (6) ladders receive the full line reference numbers with the remaining ladders receiving the first line number and the last line number per ladder. Is there a value in the wdio.lsp file that needs to change?
twright
Thanks for the tip. It worked. I also noticed that the ladders are resequenced/numbered from top to bottom/left to right. I had several ladders below others and sequence was not correct. I now know that they all have to be in a straight line left to right in the order I want them. Good to know.
Thanks again
”Boost
