AutoCAD Electrical Forum
PLC Address text options
6 REPLIES 6
Skipper488
464 Views, 6 Replies
When I insert a PLC I/O block and it asks for the first address, even if I choose one of the quick pick options, after it populates all of these and the block is completely installed the text does not fit in the little box there for it. I have to double click on it then go to each individual address and reduce the height from .1250 to .0900 and the width factor from .8000 to .5000. I have to do this individually for each address and it's very time consuming. Please help.
6 REPLIES 6
Skipper488
in reply to: Skipper488
electricman1
There is a fix for that at:
www.racklayout.com
lionSG
I use the attributes size to resize the I/O addresses.
You can modify the size and width then choose By Name to select the I/O addresses or Type It to change all by "TAG*".
Dag_Henrik
You could make your own PLC Graphics Style.
I liked to use the Graphics style number 1 but found the I/O- text to be a little small. So I went trough all the PLC type 1 "buildingblocks and scaled them up a little and saved them as style 6.
The PLC- "Buildingblocks are saved after the format HP1**, where The first letter is H for Horizonal and V for Vertical, P probably means PLC buildingblock, 1 is the style.
It is tedious work, but when done the problem is gone "forever"...
Dag_Henrik
in reply to: Dag_Henrik
Example of result...
I recommend PLC style 2.  There is no box around the address.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
”Boost
