AutoCAD Electrical General
*Expert Elite*
Message 21 of 32 (485 Views)
Re: Next Sheet Number
02-07-2013 11:46 AM in reply to: iomaxx
That looks very similar to mine but my lisp routine is named tbnp.lsp and mine handles previous sheet and next sheet.  It adds the previous sheet value to the PREVSHEET attribute in the titleblock and the next sheet value goes to the NEXTSHEET attribute in the titleblock.
The following is added to the end of the WD_TB attribute.  Must have the semicolon as a delimiter.
;PREVSHT = (if (setq x (findfile "tbnp.lsp" ))(progn(load x)(c:smileytongue:revsheet)) " ");NEXTSHT = (if (setq x (findfile "tbnp.lsp" ))(progn(load x)(c:nextsheet)) " ")
Be sure your lisp file is named the same as the call from your WD_TB.
If there is a smiley face in the code string above that is caused by this forum.  The smiley face should be a colon followed by the letter p.
Doug McAlexander
Independent Consultant/Instructor/Mentor specializing in AutoCAD Electrical, ecscad, and promis-e implementation
Web site: www.ECADConsultant.com
Phone: (770) 841-8009
Please Accept as Solution if I helped you. Kudos are also much appreciated.
Distinguished Contributor
Message 22 of 32 (482 Views)
02-07-2013 11:47 AM in reply to: dougmcalexander
after looking closer, i found it.
what's listed is missing a ( before the PROGN. it should show as
(IF (SETQ X (FINDFILE "TITLEBLOCK UPDATE.LSP"))(PROGN(LOAD X)(C:NEXTSHEET)) " ")
then it works.
thanks for the look Doug.
Active Contributor
Message 23 of 32 (472 Views)
02-07-2013 10:26 PM in reply to: mako68
how to get sheet number of currently opened drawing from autocad electrical using vb.net?
How can i get it?
Message 24 of 32 (344 Views)
10-28-2013 10:54 AM in reply to: eric.powell
eric.powell wrote:
Does anyone else have a copy of this LISP ZIP file?  I try to download it but it says that it is corrupted.
Thanks!!
Same here.
Joe Weaver
Principal Associate Engineer
Nashville Electric Service
*Expert Elite*
rhesusminus
Message 25 of 32 (330 Views)
10-29-2013 01:51 AM in reply to: iomaxx
Here it is.
THL
Please select "Accept As Solution" if this post answers your question. Kudos don't hurt either. ;-)
Message 26 of 32 (292 Views)
11-04-2013 01:38 PM in reply to: rhesusminus
Many thanks!  Very handy and was a quick fix to something someone asked for.
That's ALWAYS a good thing.
Joe Weaver
Message 27 of 32 (196 Views)
01-16-2014 01:34 PM in reply to: drathak
Well this has been working just fine until today.  I've added two new drawings and neither of them will update the Next/Prev attributes.
I've checked and they are the same title block as others that do still work.  Even exploded it to check that the code is indeed in the WD_TB attribute.  Nothing else I know of has changed.  Any ideas what might cause this to not work on a particular drawing(s)?
Joe Weaver
*Expert Elite*
rhesusminus
Message 28 of 32 (189 Views)
01-16-2014 04:27 PM in reply to: DBrohm
Check the contents of the WD_TB attribute before you explode the block.
You might have hit the roof on the length of the attribute text...
THL
*Expert Elite*
Message 29 of 32 (185 Views)
01-16-2014 04:35 PM in reply to: DBrohm
Good point Bob. I thought he had said he checked that but if he used Enhanced Attribute Editor there is a limit. Try using Properties when entering a long string of mapping data.
Doug McAlexander
Valued Contributor
Message 30 of 32 (161 Views)
01-18-2014 10:45 AM in reply to: kani_mca
What the heck is LISP? :smileyhappy:
To get the current sheet In VB.Net:
On the active drawing look in the (hidden) WD_M block. The SHEET attribute of the WD_M block is the value for the currently opened sheet.
'Next/Prev Sheet' Ids can then be found by looking in the .WDP file.
You are not logged in.
Manufacturing Community
The Manufacturing Community provides additional access to tips, tutorials, blogs and networking with peers.
Need installation help?
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
