AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
New Project Location
3 REPLIES 3
sdbell
131 Views, 3 Replies
Hi
Could anyone tell me if I can change the folder that ACE points at when i create a new project. It always seems to point to the 'Proj' folder way down in my profiles route.
Cheers
Shaun
3 REPLIES 3
in reply to: sdbell
You can edit the line in the WD.ENV file, the original of which is shown below.
**************************************************************************** Project and drawing-related paths and settings
WD_PROJ,%WD_DIR%/proj/,AutoCAD Electrical default project data folder
You can change to be like this (with your own drive letter):
WD_PROJ,H:/PROJ/,AutoCAD Electrical default project data folder
You may also need to put this (H:/PROJ) into your File Support Search path. Be certain to make a backup copy in case ACE replaces the file.
sdbell
in reply to: sdbell
Cheers Martin
When I have the default drawing open and i click 'save as' ACE points to a 'Personal' Folder somewhere in my profile. I can't seem to find anything in the WD.ENV file that relates to this path. Do you know if I can change this path elsewhere
Cheers
Shaun
in reply to: sdbell
Do you have the PROJ folder path in your Support File Search Path? This path muxt be the same as what is in the ENV file. This is the way I am set up, and the SAVEAS defaults to my specific network project folder. If this path is in the serach path, you might try moving the reference up or down, as the location may affect the funstionality (mine is the fourth line below the AutoCAD stuff, and not the last on the list).
The "Personal" folder stuff is because ACE is "Windows Compliant". Don't even get me started on that soapbox!
”Boost
