I've got some custom panel's I'm putting into our database and they have multiple views to them that we would like to use. I see that some of the default Hoffman enclosures start with the *, which allows them to explode and delete the views that you don't need, however, when I try it, everything explodes, including the attributes I have associated with it such as the assycode and mfg. How would I set this up so some blocks explode while others remain constant?
Have you create a nested block?
Create your parts with all the mfg info as separate blocks then create 1 master block from these. Once your master block is inserted "exploded", you can have each "sub part" with the catalog info already included. Just assign a BoM item number to each part if needed.
Hope this helps... If it did, please Accept as Solution and Kudos are always appreciated!
