i've entered 17 items into the multiple BOM while under the Panel Layout. When i go back to the items, the list only shows 10 and i can't edit anything past item #10. However, everything shows up on the BOM. Why can't i edit the remaining items?
In the Insert/Edit Component dialog
Click - Multiple Catalog
If you select the Sequential Code, than Catalog Lookup to change.
I don't think you understand his problem, I actually just got the same problem. I entered 30 parts last week, no problem, but today I can only change 10, since the sequential code only goes up to 10, and not 99 as is suppose to, the other 20 are hidden or something..
If i enter the same block again from the icon menu, I can enter all 30 parts again, up to 99, So I think, Lets copy everything from the old block into the new.. but Again, when I go back to the same block, it is reduced to 10 parts again... Pretty annoying
I'm using AcadE 2013 btw
I found out that it is not the block itself, because it happens to certain parts. I entered 23 of the 28 needed parts, 1 by 1, and 5 of them causes this problem, at any random order.. These 5 parts are all newly entered last week, but some of the other 23 are newly made also, and causes no problem at all.
anyone else had this problem???
I found the problem..
The problem happens when entering a part from the TRMS Family. Apperently when using something from this Family, it decreases the Multiple catalog amount from 99 to 10.
Prevent this by changing every item you want added to a part with more than 10 catalog items to a different Family code, or use a different block for the TRMS family code.
if anyone has a different solution, or a way to change this, let me know 🙂
Yes I have a solution!
Here is what i've done.
Effectively the problem is caused by the TRMS family code.
Here are the steps to avoid the problem:
The description will re-appear in the list, and also all 99 items will be accessible.
Voila.
Enjoy.
I have another solution for this problem, way more simple!!!
Just insure that the last piece on the BOM multiple catalog is not a part from the table ``TRMS`` (the table witch is the problem).
Regards.
