I'm not sure what your problem is. I have been using the program in a
networked situation since 1997. I copy the My Documents\Acade2007\AeData
folder with all subfolders (i.e. Proj, Catalogs, and PLC) to the network. I
add the network path to the Search Path under Options. Click open project
and navigate to the network path and open your project. The project should
now look to the network path for catalogs, PLCs, etc. You can also open the
wd.env file that is parallel to the Proj folder and set the default project
path. Edit with Notepad or Wordpad.
"utchat" wrote in message news:5515024@discussion.autodesk.com...
Doug,
i've done exactly as you have said. i created a new project before i moved
the folder, once the folder was moved i could only see the new project i had
created and not the default projects that ship with acade. i desperately
need my system to work this way as i have 3 of us using this software all
with standalone licenses. all 3 of us need to see the same data e.g.
cats,lib's and projects
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
