You can move a terminal block, or any component. The wire will not move with it, but the wire will join and close the gap left behind. If you want to move terminal and wire, use the copy circuit feature and delete the previous when finished. You can use a crossing window to select terminal and wire. Once copied to the new location, go back and delete the original.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
