AutoCAD Electrical Forum
Missing some manufacturers
6 REPLIES 6
731 Views, 6 Replies
On install, I thought I selected all the manufacturers from the list of those that I wanted to include in my library, but apparently I didn't. How do I install these into my program, aside from reinstalling the software?
6 REPLIES 6
Close AutoCAD Electrical first.
1.. From the Windows Control Panel select Add or Remove Programs.
2.. From the Add or Remove Programs dialog box, select the latest version
of AutoCAD Electrical and click the Change/Remove button.
3.. On the AutoCAD Electrical Installation Wizard, click Add or Remove
Features.
4.. On the Add/Remove Features page, click Next.
5.. On the Manufacturer Content Selection page, select all the
manufacturers you wish to install.
6.. On the Select Symbol Libraries page, click Next.
7.. Click Next to continue.
Hope this helps,
Pat Murnen
wrote in message news:5844275@discussion.autodesk.com...
how to install more manufacturer conten than autodesk autocad electrical 2011 provided?
mako68
You can easily  add new manufacturer and catalog  items to database in AutoCAD Electrical. If there are more (hundreds of..) products I recommend to use MSAccess or other software which can read *mdb format. You can convert the tables to Excel format and fill the information and convert back to MSAccess.
Mako
in reply to: mako68
Hi mako, how can i find new manufacturer and catalog  items?
Thanks for your help
Icemanau
Add the new components as you use them in your drawing (assuming you know the required cat/man information).
Other than that, you can always ask your supliers for a database in excel format and import that into the catalogue file using MS Access
Regards Brad
Brad Coleman, Electrical Draftsman
in reply to: Icemanau
Thank you very much
”Boost
