Solved by lionSG. Go to Solution.
Maybe you can check your roaming user folder :
C:\Users\username\AppData\Roaming\Autodesk\AutoCAD Electrical 2014\R19.1\enu\Support\User
There is a file called 'lastproj.fil' inside this folder. It maybe corrupted.
Exit ACE first then try to delete this and add new project in ACE again.
I am having the exact same symptoms on AutoCAD Electrical 2014 but cannot locate the folder above or the file in question to delete it. Does anyone have any ideas? We have Windows 7 here at CSU.
Regarding
