Multiple wires should not cause mutliple wire numbers. AcadE reads through
them and considers them one network. One thing to check is Project
Properties, Wire Number tab, make sure the "On per wire basis" is not
checked. If that isn't it you could send me a drawing directly at
pat.murnen@autodesk.com and I could take a look.
Pat Murnen
wrote in message news:5719656@discussion.autodesk.com...
Some of my wires have multiple wire numbers on because the wire is not 'one'
wire but two or three joined together, although it looks like a single wire.
Apart from deleating all the wires and re-drawing, is there a way to 'merge'
or 'fix' the wire so that ACE knows it is a single wire and requires only
one wire number?
