That is a project-level selection. Right-click on the project in your
project manager and click on the components tab. At the bottom of the
dialog click Item Numbering (see attached screen shot). You want the bottom
choice, per-part basis. The per component basis might make more sense if it
said per assembly. This is the default and is the way the program has
functioned in the past. It assigns a balloon to the top level component of
an assembly (i.e. fuse but not fuseholder, relay but not relay base or
retainer clips). So if you want the fuse to be something like item number
76 and the fuse holder to be 77, you must select item numbering on a
per-part basis. Otherwise the fuse is 76 and the fuse holder is part of the
76 assembly.
The upper section allows you to force AcadE to accumulate item numbers
across the project, rather than the default of per drawing. For example, if
you are in panel payout and you want to use the Panel Item Resequence to
auto-assign item numbers, it normally starts over for each drawing it
processes. This is normal for mechanical drawings where you put the BOM on
the drawing with the balloons. But if you are creating one BOM that
references multiple drawings, you need all of the balloon numbers to be
unique. Then you would want to select to accumulate project-wide and not to
reset with each drawing.
wrote in message news:5947197@discussion.autodesk.com...
ACADE '09: The new feature allowing the ability to put item numbers on the
multiple catalog items is great, or it would be if I could figure out how to
activate that part of the dialog box. It is greyed out on mine.
Does anyone know how to un-grey it out???
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
