Carl
You don't necessarily have to go that far. Try breaking the title block
and the drawing border into two separate blocks. Once into individual
blocks, your speed issues should subside. The slowdown seems to occur when
you are creating your drawings "on top of" a block that contains hatch and
or TTF. Having your border and title block as one entity, creates the
scenario that you are drawing on top of that block. By breaking the border
and the title block itself into separate blocks, you will no longer be
drawing on top of the block that contains the hatch and ttf.
Please give this a try, I think you will find the results you are
looking for.
Jared Bunch
Technical Support Specialist
Autodesk, Inc
"Carl Smith" wrote in message
news:401fb39f$1_2@newsprd01...
> There are some TTF in the block. The block symbol consists of the border
and
> the title box and there is a small amount of hatch as part of the company
> logo. I have a sample if you would like to take a look. Do you suggest
that
> the block not include any of these?
> "Jared Bunch (Autodesk, Inc)" wrote in
> message news:401fb28c$1_3@newsprd01...
> > Carl
> > Does your title block consist of the actual "title block" and
"drawing
> > border" as one symbol? Does your title block contain any hatch? Does
it
> > contain any TrueType fonts?
> > Regards,
> > Jared Bunch
> > Autodesk, Inc
> > news:401fb116$1_3@newsprd01...
> > > We are noticing a strange occurrence while performing the WDAUDIT
> command.
> > > When the title block is visible the command takes about 5 minutes to
> > > execute. Turn the titleblock layer off and the command executes in 5
> > > seconds. Anyone have an idea as to why this is happening?
> > > Carl Smith
> > > Avatech Solutions
