Hello.
I would like to use Location Box on my schematics, but I do not want the INST attribute changed. Meaining, whatever I put in the Location Box will take on the 'LOC" value of that box, but the "INST" should remain un-effected. Any thoughts on this?
Thanks in advance. Jeff
There should be 3 buttons next to the Installation field. These would be Drawing, Project & Pick "Like".
Just select Drawing or Project and pick the correct installation from the list. You could also use Pick Like to click on a current block to get the Installation data from it.
This should give your LOC box the INST you need to match the Dwg or Project.
Note that if you leave the Installation field blank, your components within the LOC box will have a blank INST field.
Regards Brad
Brad Coleman, Electrical Draftsman
Brad,
Thanks for your reply. I looked into your suggestions but they still cause the "INST" to change. What I have is a Location Box that contains many items with the same "LOC" but not the same "INST". If I leave the INST field blank in the Location Box it will blank out the INST value if I move a component in and out of the box. I'm really looking for a way to turn off the INST portion or defeat it in some manner.
thanks.
