AutoCAD Electrical Forum
List of "Family" codes and drawing names
3 REPLIES 3
dsonnenberg
621 Views, 3 Replies
Is there a list of the family codes and what they are short for? Some are obvious like SS for Selector Switch, but others are not. Also is there a naming convention for drawings in the symbols folder? I think I have some of them figured out like HSS113, would be a "H" Horizontal, "SS" Selector Switch, "1" First contact, "1" N.O. contact, "3" three position. As I am adding drawings and items to the databases it would be helpful to have a document on how all this was formated.
3 REPLIES 3
in reply to: dsonnenberg
I would be just a little careful in naming your library parts. The "1" you mentioned [1the 4th character in a library part name] as the "1st contact" actually means it is a PARENT, or a STANDALONE DEVICE. A "2" in the 4th position would mean it is a CHILD DEVICE, 'NOT' the 1st contact as you mentioned. VERY IMPORTANT to get the naming conventions down, and the parts will interact with each other [i.e. Parent/Child].
Glenn Buttke
Rockwell Automation
The naming convention is specified in the help
file.  Also, if you use Black Box Builder (the Electrical packages symbol
builder wizard), it will supply you with a name following the naming
convention.  If you use this method, keep in mind that the name it supplies
you, you can modify anything after the underscore.
Go to HELP > ELECTRICAL HELP TOPICS > CHAPTER
4 -- SYMBOL LIBRARIES > LIBRARY SYMBOL NAMING CONVENTION
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Is
this was formated.
There isn't a list of the existing family
codes in the documentation. I went through the Appendix A
page by page and assembled them and put them
in a excel file, to which I add when adding
a new family.
I can e-mail the file to you - I'm not sure how
to attach it here.
toland@gtequipment.com
”Boost
