AutoCAD Electrical General Discussion
New Member
MCI_ELEC
Message 1 of 3 (671 Views)
Latch Relay and Unlatch Relay, Should be a single component.
671 Views, 2 Replies
11-09-2012 02:51 PM
I wanted to use a latching relay so I inserted the symbol for a latching relay from the Component Menu on a rung, but when i go to insert the unlatch input or coil for that same latching relay it assigns a new coil without asking me for the parent latching relay. the item that I am trying to model is an 8501KL12V20 Latching Relay from Square D where you have a common connection for two inputs. One input latches the relay and the other input unlatches the relay. How do I make this happen? I need it to be a single component.
johnq
Message 2 of 3 (600 Views)
Re: Latch Relay and Unlatch Relay, Should be a single component.
11-18-2012 04:56 PM in reply to: MCI_ELEC
G'day MCI
My solution was to draw a three wire coil using the standard relay coil.
The unlatch wire was connected to the bottom of the coil.
I then made a special block.
Icemanau
Message 3 of 3 (593 Views)
11-18-2012 08:08 PM in reply to: MCI_ELEC
I created a special block that has both the latch and unlatch coils in it.
There is also the ability to tie two parent blocks together within ACADE using the WD_ALTTAG attribute (I think that's it).
Regards Brad
Icemanau (NNTP handle: Brad Coleman)
You are not logged in.
Manufacturing Community
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
