AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Last wire number help - Nate Holt
4 REPLIES 4
Fdna49
341 Views, 4 Replies
I use the following file to automatically populate a last wire number attribute in my tileblock. Although it has worked fine for years, I recently upgraded to 2009 and it doesn't work anymore. Can anyone advise as to why it dosent work anymore?
; 22-Feb-05 NEHolt created
(defun c:lastwnum_proj ( / ss exclude_num_lst ix slen rtrn wireno maxnum en val)
; Scan active project and find "last wire number" used. Drawings needs to have been processed
; by AcadE's AUTO WNUMS command or wire numbers manually inserted using AcadE's EDIT WNUM
; command. This routine can be encoded into AcadE's title block update mapping file to
; automatically populate a target attribute in the title block with the last wire number
; used on the entire project.
; Note, issue a (command "_.QSAVE") prior to calling this routine if the current drawing
; has had its wire numbers updated and the project database not freshened.
(setq rtrn "") ; default to return a blank space if no wire numbers found
(if (not GBL_wd_m) (wd_cfg_read_dwg_params)) ; read WD_M block if necessary
; Step 1 - get list of all wire numbers found on DESTINATION signal arrows. These numbers
; will be excluded from the calculation because the wire number was assigned on some
; other drawing.
(setq exclude_num_lst nil)
(setq maxnum 0)
; Get list of all project's wire number, 1=freshen database, nil=don't exclude active dwg
(setq lst (wd_mdb2_get_proj_wnums 1 nil))
(if lst
(progn
(foreach wireno lst
(if (AND wireno (/= wireno "")) ; wire number is not blank
(progn
(setq val (atoi wireno)) ; convert wire number to integer value
(if (> val maxnum)
(progn ; this wire number is biggest so far. Save it.
(setq rtrn wireno) ; return highest wire number so far
(setq maxnum val) ; save highest value so far
rtrn ; return "" or highest wire number found on this dwg
Chad
4 REPLIES 4
in reply to: Fdna49
Chad, this seems to work ok for me in 2009. Do you see any errors? Does it
return anything?
Pat Murnen
wrote in message news:6022564@discussion.autodesk.com...
val)
have been processed
AcadE's EDIT WNUM
mapping file to
last wire number
current drawing
freshened.
necessary
assigned on some
; other drawing.
(setq maxnum 0)
exclude active dwg
(if lst
(progn
(foreach wireno lst
(progn
(if (> val maxnum)
Chad
Fdna49
in reply to: Fdna49
Hello Pat,
After trying it on another project, it is running, just returning a "blank" value.
The following are copied from the AutoCAD text window
From 2008
Interpreting as AutoLisp: (IF (BOUNDP 'C:LASTWNUM_PROJ)(C:LASTWNUM_PROJ)"")
reading project database file...
Updated LASTWIRENUM: 3 --> 6
From 2009
LASTWIRENUM (no change)
So it appears that 2009 is not reading the project database?
in reply to: Fdna49
It seemed to read it fine at my end. Can you send me the project and the
.wdt file if you are using one? My direct email is pat.murnen@autodesk.com.
Pat Murnen
wrote in message news:6023034@discussion.autodesk.com...
Hello Pat,
value.
From 2008
From 2009
in reply to: Fdna49
Turns out the file just wasn't getting loaded when each drawing was opened.
This needs set up for 2009. Follow this to have a .lsp file loaded each time
a drawing is opened.
1. in AutoCAD type APPLOAD
2. down at the bottom there is a Startup Suite section. Click Contents.
3. Click Add and navigate to where the .lsp file is to add it
4. Close and Close
5. Exit AutoCAD and then restart
Pat Murnen
Hello Pat,
value.
From 2008
From 2009
”Boost
