You can have up to 4 ladders per drawing. That is the reason for 4 groups
of boxes. You can change the spacing and/or numbering of your line
reference numbers, click Redo and OK. What this tool does not do is
changing the spacing of the actual wires that make up the rungs. The scoot
command can be used to "nudge" the wires up and down the ladder rails,
unless you have already inserted components and you have vertical
connections from rung to rung. This requires a bit more editing, using move
component, trim wire, etc. It is best to decide your rung spacing before
you start inserting component symbols.
wrote in message news:5728689@discussion.autodesk.com...
Could you please help me how to renumber an existing ladder.
I just choose the Revise ladder button, then the Modify line reference
Numbers dialog box was displayed. My question is what for the four rows are
there under the Rung Spacing, i mean what is the use of the 3 rows under the
first row, how can we use those. Also, what is the function of Redo
checkbox. and when will be More and Back button available.
Please help.
Thanks in advance.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
