AutoCAD Electrical General Discussion
Active Contributor
egrigg
Message 1 of 3 (315 Views)
Inventor to Autodesk Electrical
315 Views, 2 Replies
11-07-2012 10:01 AM
I created a wire harness in Inventor with all the refdes in place and so on, I then exported the XML file. I successfully imported the XML file to Autocad Electrical however my wire colors do not display on my screen. The wire layers show they are active, and the wires have the correct information.
Can anyone explain what I am doing wrong or how to display correct wire colors.
Thanks in advance.
Erik
Autodesk Product Design Suite, Ultimate 2013
Valued Contributor
lionSG
Message 2 of 3 (307 Views)
Re: Inventor to Autodesk Electrical
11-07-2012 06:05 PM in reply to: egrigg
Think after you imported the xml from Inventor, you need to go to the create/edit wire type and change the wires layer color to the correct color you need. By default it is white if I remember correctly.
Thanks.
Active Contributor
egrigg
Message 3 of 3 (284 Views)
11-08-2012 08:40 AM in reply to: lionSG
You are correct, the wires come in white. It would be nice if that were automatic.
Also is there a way to import the wire lengths so that you could display them in the schematic?
Thank you!
Erik
Manufacturing Community
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
