I installed Allen-Bradley, Automation Direct, Honeywell, and others when I installed my software, however, only Allen-Bradley is available on my vendor select list.
I already tried the repair/modify procedure and the others were checked as if they were installed. I did the repair anyway, but it still didn't work.
Any help is appreciated.
Jeff
Each type of component (PB, Relay, etc) has their own table and it might be that the components for those particular manufacturers are not in the table you are looking at. ACAD does not supply the full catalogue of each manufacturer, just the most common items.
Try looking under some of the other component tables to see if they show up there.
Regards Brad
Brad Coleman, Electrical Draftsman
Go to uninstallation page, click Add or Remove Features button, click Next to launch Manufacturer Content Selection page, check if the other manufacturers are selected or not, if not, select them and click Next to install them.
Kevin Li
